1x Used Standard BNR32 RB26 Timing Cover - $60
1x Used Standard BNR32 Bov's - $80
1x Used Standard BNR32 Clarion Power Amp - $20
1x Brand New Apexi PowerFC Boost Control Kit (415A001) - $300
1x Brand New Tomei RB26 Head Gasket 1.2mm (1321870123) - $300
1x Used Apexi Power Meter 60mm Gauge - $100
1x Used ARC Bov - $40
1x Used Unknown Brand Parcel Shelf Brake Light - $20
Open to offers on everything. Items located Queensland 4129 with pickup or postage :).
https://www.sau.com.au/forums/topic/421739-bnr32-rb26stockaftermarket-parts/
Hey champ that timing belt cover does it come with bolts
A pair of rebuilt R34 GT-R turbos (A/R.53 front .48 back steel turbines with all gaskets), not even 5,000kms travelled - $500
(will post pictures this afternoon)
Edited by ADUBZ
Turbo's SOLD.
Here's whats left:
1x Used Standard BNR32 Clarion Power Amp (Active Speaker) - $20
1x Used Apexi Power Meter 60mm Gauge (450ps model) - $100
1x Used ARC Bov - $30
1x Used Unknown Brand Parcel Shelf Brake Light (Used for road worthy) - $20
Edited by ADUBZ
  • 3 weeks later...
  • 8 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
