R33 gtr inlet manifold $100
R33 gtr ac bracket $25
R33 gtr s1 ecu to engine loom $150
R33 gtr s1 coil pack loom $100
R33 gtr knock sensor/aac valve/ cold start valve loom $100
R33 gtr o2 sensors, look quite newish $50 each or $75 for the pair
Rb25 starter motor $50
Rb25 alternator $50
S15 center console (part with cupholders), inc ashtray $75
S15 coil packs 3, $50 each or 100 for the 3
All parts located brisbane northside, pickup ok or i can post at your expense
Prefer contact via pm thanks
Mick
Edited by Gts30t
https://www.sau.com.au/forums/topic/421996-r33-gtr-rb26-rb25-and-s15/
Rb25 alternator $50
Mick
have pics of center console? [email protected] thanks
Console is not quite as good as i remember, it has no lid either. Would suit someone who wanted to paint it as i t would come up really nice. Price drop to 50
F1FB3445-5651-42F8-8A9D-EF9439433EC5-302
1E1F012D-28FD-45C6-8920-14EE79649506-302
R33 gtr engine looms and sub looms
EB56E8FC-66BC-4934-9ED7-AA7E63539A92-302
Also have a polished rb20 crossover pipe for sale, $75
R32 gtst air con compressor $100
