Hey guys, just changed my fuel filter and forgot to remove the fuse and crank the engine to relieve pressure.
Didn't matter anyway as there was only a tiny amount came out of the fuel hose when i removed it to get to the filter, last time i did it there was a fair bit of pressure there still.
Iv'e looked around and cant find why, i also don't have the "whoosh" sound when i open the fuel cap if that's any indication.
Walbro gss-342
555nismo injectors
New fuel filter :whistling:
I have deleted the carbon cannister, blocked off the hard line on the drivers side and removed the one on the passenger side (it just stopped near the cat with an open end anyway)
I dont know much about fuel pressure regulators or anything else attached to the system or how to check it.
Theres no leaks and no strong smell of fuel, has anybody got any ideas or tests i could do.
Search wasnt helpful at all, nothing came up for any fuel related queries.
Cheers
put your filter in backwards?
or didnt mix your lines to the reg around the wrong way by any chance...
not that I've ever made that mistake before :whistling:
HA that's the first thing i checked on google images, surely everybody cant be wrong :wacko:
MAD082, i was just reading about sealing the filler neck in the FAQ and i'll go and look for a new fuel cap, cheers.
Is the fuel regulator the one on the end of the injector rail? Got a feeling it is but whats the one attached to the body under the master cylinder?? another regulator??
The R33 manual is 3 books of not much help at all.
You have two different questions happening.
The lack of fuel pressure is probably your pump.
Rail pressure is maintained between the fuel reg and the pump, but to do this many aftermarket pumps need a non return valve fitted.
If the reg is working properly and so long as you can start without a few key on/offs don't worry about it. Pumps like an 044 are notoriously hard to start without a non return valve.
The whoosh at the filler cap is often caused from a poor seal job of the reduced neck when complying. But you've also removed the carbon cannister and its associated plumbing. I'd be more concerned that the tank can breathe as fuel is removed.
Thanks Jiffo, yes it does start on the first crank so maybe not a problem after all. I have resealed the filler neck and will replace the cap anyway though.
I might put the carbon canister back together then for breathing purposes, my only concern was the line that ran down the passenger side just stopped around the cat area with an open pipe.
I cant seem to find if it should be left open, i had a look around and cant find anywhere to connect it to.
Quick question: before it was imported, was there a carbon canister on there from the factory? I cant find much info at all on them.
I wish I knew this when I was fitting my 040 in-tank!! Will have to source a check valve and pull it all apart again so it starts properly. For now I just try and remember to let it prime fully before starting but often I'm impatient and forget. Definitely annoying...
Do a couple of key on/offs to prime the system, it's the cheapest option.
The ecu times out the pump after about 5 seconds and often that's not enough time to fully prime.
The Bosch non-return valve is quite restricting, I'd suggest the tune will need a touch up if you fit the valve to a previously tuned fuel map.
hadn't thought about it being a restriction. car still has a standard ECU so not an issue yet. old habits die hard I usually get in the car turn the key and it is running after half a second. having to wait for a daily's pump to prime is painful, and it sounds gay when I forget to wait and it won't start properly.
just change your routine slightly and that will make life easier for you. just start letting the pump prime before you put your seat belt on. my commodore daily developed an issue lately where it wouldn't start cleanly without priming first, so i just started doing what i said and it made life a little bit better.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
