VIC: R33 RB25DET S1.5 273RWKR ENGINE
Since getting a work car 4 years ago my skyline has sat under cover in the driveway and only done 1000k’s or so. With it costing reg and insurance it’s time to sell it up and move on to the next hobby. I’m looking to break it up starting with the engine only seeing as it’s worth the most (over $10,000 in receipts spent on toughening it up).
It’s a strong, well maintained engine with oil and filter changed every 10K kms. It’s still in the car and running to be seen. It’s done 56K km since the rebuild (156K kms total on car). It did 600kms on the freeway each week for 2 and a half years so it’s been a pretty easy life since the rebuild.
Engine
RB25DET S1.5
Power
273rwkw (with dyno sheet)
Head
Ported & polished with angle cut valves and Tomei head gasket
Pistons
Forged - Venolia USA
Cylinders
Machined and sleeved
Rods
Shot peen strengthened
Crank
GTR
Injectors
Denso 740cc
Airflow meter
Q45 Infinity AFM
Air filter
Pod – could do with replacing
Turbo
Custom: Ball bearing: Equivalent to GT2876R? Compressor – A/R 0.70, HKS exhaust housing – A/R 0.64.
Wategate
Internal
BOV
GReddy
Boost controller
Simple bleed valve
ECU
Power FC tuned rich for the motors longevity
Asking $3,900 for all of the above. Negotiable and may break further depending on interest.
Once the motor’s SOLD the rest of the goodies in the car will appear here…
  • Gearbox with short shift kit / full drivetrain.
  • Impul light weight racing rims (17in white 5 spoke).
  • GTR rear spoiler / Veilside pods / skirts.
  • Full black coloured body with resprayed roof and bonnet.
  • Blitz 3in catback exhaust / x-force dump-front pipe.
  • Apexi intercooler.
  • Recaro seats.
  • Nizmo 300km/h dash cluster.
OR…. $8,400 for the whole car as is.
https://www.sau.com.au/forums/topic/422534-vic-r33-rb25det-s15-273rwkr-engine/
Motor's still available. Some interst but not enough to break it up into single pieces.
Any reasonable offers considered but please no timewasting dreamers because I won't be given away for what it is.
  • 1 month later...
It's begun......
Deposit taken on the motor in pieces.
Still for sale are injectors, Power FC (no controller), BOV, turbo, dump/front pipe etc...
Anything required to keep it rolling will not be for sale "yet".
Just being dismantled so prices to come.
Reasonable offer considered in the mean time.
  • 3 weeks later...
Hi guys,
I'm after $650 for the power fc without a hand controller.
The cluster I'm after $350. The tacho is playing up but the price is purely for the nizmo speedo as part of the cluster.
Cluster pics are in the post from when it was going to get sold as a car:
http://www.skylinesaustralia.com/forums/topic/422952-vic-r33-gtst-95-s15-273rwkr/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
