Hey Guys
Got some R32 and R33 GTR parts sitting in my shed that need to go.
Contact details: PM or reply here
Cheers Greg
6 x 700cc power enterprise top feed 11mm same as sard injectors just in a different box. Only done a couple of runs on the dyno before they were replaced with larger id1000's. $500 including postage. Pic
R33 GTR Vspec rear subframe, come with diff, hubs, arms and handbrake setup, no calipers, rotors, swaybar, half shafts $400
R32 GTR front diff, 4.11 ratio inlcudes everything pictured $100 Pic
R32 GTR BOV return pipe that runs behind the intercooler, no cracks $25
R32 GTR engine mounts $25
R32 GTR strut brace $50 Pic
R32 GTR front uprights, includes uprights, hubs, half shafts and lower control arms $100 Pic
R32 GTR slave cylinder $20
R32 GTR clutch booster and master cylinder $40
R32 GTR speedo cable $25
R32 GTR front sub frame and swaybar $50
R32 GTR power steering reservoir $5
R32 RB26 fuel rail $5
https://www.sau.com.au/forums/topic/422598-rb26-and-gtr-parts/
Couple more things added
HKS low mount cast manifold, bought this about 3 years ago then changed plans and it has just been sitting around in bubble wrap. It has a crack between the dividing plate as you can see the in pictures $550 including postage
  • 3 weeks later...
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
