Want to trade:
AM Performance Catback Exhaust
Enkei RPF1 17x9 +22 or similar lightweight 17x9 +20ish wheels
Located Melbourne, Eastern Suburbs. Please contact me via pm or 0422 889896. Thanks, Alex.
VELO MILANO XL w/ MONZA 4-PT HARNESS
Drivers seat for sale (passenger sold) has tear from getting in and out but does not effect function.
Milano XL retails for $700. Not sure what the Monza harnesses are worth but Velo's equivalent starts at $150.
Drivers $300 takes into account the tear.
Drivers
Tear.
Just the seat, the rail and mounts are in poor condition and I won't sell it in fear of one us having the seat separate from the rail :/. If you have stock rails the mounts can be made easily as the seat is bottom mounted, two pieces of flat and two nuts welded on the flat done ;).
Dimensions http://www.velo.com.au/site_files/421/velo...ght chart.pdf
Grab a bargain before trackday! :lol: Bucket seat and harness are an awesome mod,
NISSAN S15 GT LEATHER SEATS
Immaculate condition. $550 $450ono
ATP T28. Rebuilt and balanced at ATP 3000 kms ago. Rebuild cost $600, sell $500 ono with braided water lines.
Essentially brand new, still on the car more than welcome to come see it. Don't buy 1,2 or 3 fkd second hand T28s with 150k+ kms, 2mm play and fkd bearins/seals, save yourself headaches, money and buy this one.
Rebuild pics/text. Kyp wanted to show-off when he rebuilt it lol. Post #58.
http://forum.jdmstyletuning.com/showthread...ced#post1303342
Finished after rebuild. Post #61.
http://forum.jdmstyletuning.com/showthread...hlight=balanced
NISSAN S15 BOOT
No wing, debaded and dekeyholed (? lol). Perfect condition. Red $400 $300 firm.
BLITZ NUR SPEC EXHAUST
$450 ono be awesome and buy this zorst or im going to keep it and ask Ben to make me 400 mm decat lol[/color]
APEXI N1 EXHAUST
$450 ono, relatively quiet, free flowing, APEXi nuff said.
Can throw in decat for $50 if you're so inclined lol
S14/S15 305x9 mm ROTOR CALIPER ADAPTER, incl 2-PIECE ROTORs $220 ono
Bolts on to stock knuckle so S15 handbrake still operates. Perfect for someone running BBK or R33 calipers up front without wanting to spend extra on R33 handbrake setup. Only surface rust, will be cleaned up before sale.
Full S15 Exhaust NOW $130!
SMIC shroud NOW $10
S15 Stock Fuel Pumo NOW $40
T28 Split Dumps Top both NOW $20
Cats gutted NOW $15 [/color]
S15 Stock Front Swaybar NOW $40
S15 ECU Bracket NOW $FREE ZOMG FREE SHIT ZOMG OMG OMG TAKE IT!!!5
UPDATED
Drivers
Tear.
NISSAN S15 BOOT
APEXI S15 N1 EXHAUST
SMIC shroud NOW $10
Cats gutted NOW $15[/color]
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
