Got a heap of parts in the shed i need to clear out
S13/180SX - STOCK
stock front pipe - $30
stock dump pipe with oxy sensor - $50
4 stud hubs with good bearings - $10ea
sr turbo front brakes with disks and pads - $100
Hicas power steering resivour with level sensor - $50
Hicas subframe with all Hicas lines, senders, lower control arms, disks & knuckles - $150
AC condensor with lines - $30
AC compressor with idler and brackets - $50
R180 diff (suit 5x1 half shafts) - $100
half shafts (5x1) - $50ea
interior fan and heater core - $15
AC interor core - $15
hicas PS pump - $50
T25 turbo on standard manifold - $150
clutch fan shroud - $35
stock intercooler with piping & BOV - $50
charcol canister - $5
standard suspension arms - $20ea
most interior parts available
AFTERMARKET
Blitz aluminium mandrel bent piping to suit front mount - $150
3" front dump pipe (mandrel bent, mild steel) with oxy sensor - $50
C34 STAGEA
wrecking a c34 stagea (no gbx, motor, suspension or brakes), if any parts u want aren't listed let me know as i probably have it
interor fan with heater core - $15
AC interior core - $15
front seats - $50ea
door shells - $30ea
rear hatch shell - $40
roof rack - $30
passenger side rear hatch glass - $50
dash - $50
carpet (minus hatch area) - $15
headliner - $15
visors - $5ea
rear seats (top section only) - $40
steering wheel (with radio controls) no centre - $40
auto shifter - $25
wiper and indicator stalk assemblies - $30ea
front & rear seat belts - $30ea (or the lot for $120)
front driveshafts (drivers side needs repair) - $30
front AWD knuckles - $30ea
ABS unit - $30
front X-member - $30
rad overflow bottle (good condition) - $25
UNIVERSAL
5x114.3 space saver spares - $25ea
floor mats - $5 set
I'm chasing the following parts (trade for above with cash either way)
bosch 040 (or equivelent) fuel pump
fixed back racing seat (medium or large)
180sx stock front bar
injectors to suit sr20det (other then factory s13)
17x8/9 5x114.3 skid rims
215/45/17 tyres
r33 turbo front brake disks
R33/r34/s14/s15/c34stagea rear adjustable toe arms
R33/r34/s14/s15/c34stagea rear adjustable camber arms
https://www.sau.com.au/forums/topic/422857-180sx-s13-silvia-stagea-parts/
  • 1 month later...
if u mean roof then yes, if u meant the actual hood then no, car had a pretty solid front end hit so no pannels infront of the doors
btw located in whyalla, but in adelaide every second weekend
the followng parts have sold
180sx clutch fan shroud
stagea front doors
stagea rear hatch
stagea front half shafts
all other parts still available
stagea front doors
stagea rear hatch
hi yeah I was after the back half of the roof lining ( hoodlining ) but I'm in sydney so unless u come up here I don't think ill be getting it cheers tho
going to be dropping the stripped shell with all wiring at the wreckers in the next week or so
If there are any connectors/peices of loom that people want let me know ASAP and i'll cut it out of the loom for you, happy to give it away if u pay postage/pick it up in either whyalla or adelaide
    • Private profiles, adult chat, and local dating in one place https://privateladyescorts.com discreet sex dating
