Well after a lot of time messing around on the net and doing my research I bought this:
I thought it would be ideal because it had bluetooth connectivity and was steering wheel remote ready and thanks to Commsman who sourced and supplied the buttons I have steering wheel controls with my cruise control. I did some research and came to the conclusion that this unit was the one for me because it had orange illumination similar to the factory colours. What I didn't take into account was all the usb, aux and mic ports were at the back of the unit and needed to be plumbed into the car somehow.
Some more research later and I decided that I need an Xtrail loom to make the steering controls work with my new head unit, so I bought this from the U.K.
It actually had ISO plugs on it the loom which I cut off to mate to my JVC loom which I rigged up to put in and test out. So I'm all ready to go, I just have to connect that brown wire at the bottom of the picture to this wire:
How easy is that????? Not very it turns out!
I pulled my dash apart with some guidance from Jetwreck and the youtube tutorial and went to install it. DOH! The body loom plug is incorrect and because I've hacked the ISO plugs off, I can't send it back. To say I was pissed is an understatement because I was misled, in my opinion, by the ebay seller who said it was plug and play.
Anyway, undeterred I tried again with an Aussie seller that was double the price but was assured it was plug and play. When I got the new unit it looked identical to the previous one but with different body plugs(!) and the brown wire was still loose and they had the jack plugs connected. I trusted that it was right and just plugged it all in and the stereo was working, a small win! After driving for a few days I found the radio reception was rubbish and it really annoyed me.
Then my luck changed! I got onto these guys:
http://www.yellowpages.com.au/tas/launceston/car-accessory-installs-12430245-listing.html
Ky went through everything I did and discovered that I hadn't pulled out the FM expander that was there for the Jap spec stereo. So, I pull it all apart again and then drove the car down to them to look at. Ky stopped working on another car and fixed the reception issue by removing the fm expander and looked at the control box and loom I bought and thought that one of the wires was wrong as did I. Anyway, he snipped the jack plug off and connected the brown wire to the blu wire with yellow stripe and success!!!!!! Steering wheel controls work!!!!
Pretty.
So how much did Car Accessory Installs charge me for this? Not a thing!!!
I drove home and put it all back together and routed the ipod plugs and bluetooth microphone through my ashtray.
Voila! I am one happy camper right now.
I wish I had of taken my car down to Car Accessory Installs in the first place as they have converter boxes that can be tuned to ANY head unit to make your steering controls work as long as the head unit supports it. They also sell all the accessory's required to make it work so a free plug for them.
Now I have cruise control which I love and steering controls which work.
Edited by richzx
Good one Rich! Great to see you've (finally) had success & worth a free plug to a business who looks after you so well.
Hope they get rewarded by heaps of paying customers turning up on their doorstep.
Excellent work!
Good to see a local business supporting enthusiasts! One recommendation can get you tonnes of business.
​Link to moccasin purveyor? :whistling:
These guys are great for mocco's! I just bought my bro in Sydney a pair and he's here tomorrow for the Supercars.
http://www.allgoods.com.au/
  • 2 years later...
Ill just bump this thread up a bit as i now own this stagea and jvc head unit is showing age and stole one of my cds and refuses to give it back. I have installed a pioneer head unit that has a small audio style jack for input of steering wheel controls. Can u use jack from the aerpro control unit and plug straight in to back of stereo? I ahould have asked before i put it all back together but its an easy job
You should be able to; the control only uses 2 wires.
The control just uses a bunch of different resistance values that are then programmed into specific functions.
When setting up, I'd imagine it will ask you that press a button for a specific function, then allot that resistance value for a particular command.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
