hi guys,
Recently after fixing the gearbox problem and throwing in a dump pipe, ive noticed that when the car is given a big push throttle to the floor n stuff. it feels like its holding back.
What is going on ? anyone please
other than that she does good.
https://www.sau.com.au/forums/topic/422889-i-have-a-little-issue-please-help/
well its a 33 gtst. the other thing i figured out with this issue when the car on a warm day will run better than when in the cold weather.........
shouldnt it be the other way around ( boost hits max in warm day) Will cough and struggle in cold day/nights. )
possibly, i changed afm last year coz the old one took a holiday, coil packs could be a maybe. Actually thanks for that, ill suss out these things and let you know what comes out of it.
cheers!
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
