Originally posted by hungry6
i got a 700hp one in the tank and it pretty easy to do just a lil bit of handy works and make sure u use the right type of fuel line, as most will deteriorate when submerse in fuel. also is abit noisy
Okey, can u tell whitch modell it is and where to bye one of those for my car?! R33 Gts-t.
Maybe u have the serialnr on the pump?!
How mutch is it flow?!?
Regards Klas
yes the pump have to go inside the smaller but deeper section of the tank. u have to modify your bracket(cutting) slightly so it'll fit down there. also there is another bosch pump that will flow 600 hp and it has a gauze on the end and it a neater fit. but the one i got is by NEKO some where from japan and it is huge but it has a pickup tube and slip straight into the stock bracket.
Originally posted by ricknismo
I have a bosch 044.I think its rated to 600hp.In the tank there is 2 distinct pockets.One with the 'level' tube and a deeper, bigger looking one.Wouldn't you go for that area with the pump tube.
044?? Whats the hole serial nr?!? ex, ???-???-???-044 its a longer nr then 044, that nr is in the end of the serialnr, right?!
If i dont remeber wrong so has the Audi S2 Coupe and avant, this modell of feulpump?!?! nr 044 on the end.
No one ho now whats in the gts orginal?! serial nr and brand?!?
Regards Klas
Can u tell some more of the pump, maybe some urls and so on, need a pump and i needed it fast =))
Klas
i got myself a R33 GTR fuel pump & it works like a charm, i cant remember the rating of the R33 GTR fuel pump but im pretty sure its around 400cc or so.
All you need is a hose clamp 2 install it & just swap them over & your pretty much done, but what i would do since your playing around with the fueling system already is 2 change the fuel lines with some new hoses.
Standard:
A42-T24
002
unisia jecs
12v
5619c
Thats all that is written on the pump,make of it what you will.
Bosch 044:
0580254 044:burnout:
Yeees at last i got it, thanks mate =)
You are a guru on that sort of thing man
:P;):)
Regards Klas
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
