I have a set perfect condition i remember few years back to get brand new thru nissan it woud cost over $1000k make a offer to me etcetc if happy we conduct some sorta arrange ment if in other state wil be posted etc pm me for further correspondance.
Regards
Allan.M
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
