Hey all,
For the first time on the weekend i used my R33 GTR for something more then getting to and from work!
And ive caught the bug. Two events i LOVED so im looking at setting my car up for these two things only. (Plus going to work!)
My questions are on tyres
The first Event is straight out drags and the second event is go to whoa.
For people that dont know what it is, its run over the 1/4 mile from a standing start then at the end is a braking point and you have to stop the car inside two cones. First to stop dead inside the cones wins.
I used my normal street tyres (sorta crappy ones at that) on the weekend. I got a bit of wheel spin at the start and also the braking / stopping was a bit rubbish.
Im going to get a set of eith R33 GTR or 34 GTR rims to put specific tyres on just to use in these events etc.
Whats the best to go for? as i need them to be sticky but also need them to be able to stop very well?
Will slicks stop?
Will Semis be the go?
Or is there another option i should be looking at?
Any brands worth looking at over another?
Any help would be great,
Thanks
535847_458449340898078_2051093298_n_zps4
https://www.sau.com.au/forums/topic/423250-slicks-semis-or-other/
Both semi and full slick tyres will be better than standard road tyres however only if they are warmed up properly.
By properly I mean you will need to do a burnout for a handful of seconds and even then the fronts wont get any warmth. You will need to do this for every run too! Braking will also improve, but once again only if they are sticky and your brakes will need to be up to temp properly anyway which they never will be for this type of event.
  • Like 1
the current crop of soft compound semis would probably be best thing for go-whoas. normal compound semis definitely work better with a bit of heat, but are still pretty good cold. I've done plenty of hillclimbs on cold semis over the years.
personally, I'd try some better street tyres before going to the trouble and expense of a seperate set of wheels and tyres. Even if you went to semis later, good street tyres are still worth having.
  • Like 1
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
