Hey all,
Not sure what place to post this question.
Im looking at reducing weight in my R33 GTR.
Im just after ideas and opinions from people who have done it to GTRs before
Obviusly there is little reason to change the aluminium bonnet and gaurds, but what about the boot?
Im stripping the underside of the bonnet also.
Does anyone have any idea what the driver and passanger seat and rails weigh each? Is it worth changing seats?
How much sound deadner is under the carpet and roof lining? is it easy to remove?
The rear seats, parcel shelf and belts etc will be removed
The boot carpets and plastics will be removed
What else is worth doing?
https://www.sau.com.au/forums/topic/423279-weight-reduction-and-weights/
Hey Adam, I think there is a thread in the motorsport section about weight reduction for a 33 GTR
I weighed the front seats with rails a while ago and I'm pretty sure they were 14-15kgs each
Get a lightweight odyssey battery and remake the bracket for it with aluminium
Get a midori titanium front pipe, cheap at the moment with the good exchange rate
Still got the a/c and stereo or have they gone in the bin?
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
