Parts off my car for sale.
Apexi Power FC L Jetro for R34 GTR = 1000 ONO pick up or posted
R32 Air Flow Meters x 2 = $50 each pick up or posted at buyers expense
RB26 Rubber intake pipes = $80 pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = $300 pick up only
Non genuine Sard Fuel Pressure Regulator (Came with the car and only found out after taking it out) = $50 pick up or posted at buyers expense
Willing to combine the Greddy fuel rail and pressure regulator if someone wants as a package.
Items located in Liverpool NSW.
PM if interested.
For some reason SAU won't let me attach pics, will try again tomorrow.
I can also send pics via mobile if needed.
Cheers,
Will
still got the computer for sale? I am looking for a power fc to suit R33 GTR. Am located in Liverpool
Power FC is still available, though i don't think it will work on an R33 GTR.
Fortunately for you i do have mate whos thinking of selling his Power FC from his R33 GTR Vspec.
PM me if your interested
Apexi Power FC L Jetro for R34 GTR = PRICE DROP $900 ONO pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = PRICE DROP $250 pick up only
Hi Guys
Just an update, it turns out my SARD fuel pressure regulator is Genuine, thanks to a forum member enquiry i double checked it.
The website i used is linked below:
http://www.silviawa.com/forums/index.php?showtopic=39446
Point 2 confirms that mine is genuine, see pic in the first post.
I will be bumping the price up to $150
Apexi Power FC L Jetro for R34 GTR = $900 ONO pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = $250 pick up only
Genuine Sard Fuel Pressure Regulator = $150 pick up or posted at buyers expense
Apexi Power FC L Jetro for R34 GTR = PRICE DROP $850 ONO pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = PRICE DROP $200 pick up only
Apexi Power FC L Jetro for R34 GTR = FINAL PRICE DROP $700 FIRM pick up or posted at buyers expense
R32 Air Flow Meters x 2 = FINAL PRICE DROP $20 FIRM each pick up or posted at buyers expense
RB26 Rubber intake pipes = FINAL PRICE DROP $50 FIRM pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = FINAL PRICE DROP $150 FIRM pick up only
Genuine Sard Fuel Pressure Regulator = FINAL PRICE DROP $100 FIRM pick up or posted at buyers expense
Apexi Power FC L Jetro for R34 GTR = $700 FIRM pick up or posted at buyers expense
R32 Air Flow Meters x 2 = $20 FIRM each pick up or posted at buyers expense
RB26 Rubber intake pipes = $50 FIRM pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = $150 FIRM pick up only
Genuine Sard Fuel Pressure Regulator = $100 FIRM pick up or posted at buyers expense
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
