Hey guys. The other day I took my whole dash out of my r32 GTR to replace with one with no bubble in it.
When I put it all back together everything worked but the speedo which I can fix.
The problem is now all of a sudden the car is running very rough like it has a miss and I took it for a drive to see if it would clear up then power steering cut out and the hicas light came on.
Can any of this be my doing from pulling the dash out? It all just seems too coincidental that it drove fine before I parked it and removed dash (which I'm now highly regretting). Need to know what this could be as its due for a pink slip
:( not my week.
https://www.sau.com.au/forums/topic/423571-need-help-diagnosing-a-problem/
You have two problems.
The HICAS and power steer should clear up as soon as you fix the speedo.
They both need input from the sender on the back of the speedo, the power steer will go very heavy without speedo signal input.
Your miss is probably poor contact at the big blue ecu plug.
With age this plug develops a bend therefore the end pins often don't make contact.
I always help the plug to fully engage its end pins as I tighten the centre bolt.
Seems to be worse with the PFC contacts for some reason, car runs like a Subi.
Try pushing in the plug with the engine going, you'll soon tell if that's the fault.
next time cover the bubble with a dash mat :-)
jiffo is quite correct, the ecu plug bends like a banana, doesnt help when dopey auto electricians overtighten it and distorts it even more
Oh my god jiffo you could be a massive lifesaver that makes a lot of sense. I've been stressing so bad about this not even being able to sleep cause i have a pink slip due very soon.Thank you so much for your comment ill test it out tomorrow. Thank you thank you thank you :)
Steven I think I was the dopey dogey fix it man in this one. As soon as the dash was out I thought to myself "my god what have a done" lol. Tho was very happy everything worked when I put it back together other than speedo and didn't miss a screw hahaha
eeeeeeverybody who has a skyline has been at that point.
haha. I threw 5k at a HKS turbo, nismo injectors, a computer n tune.
2 days later i blew a boost pipe. (big bang under boost/WOT then it runs rough as guts with smoke coming out the back).
Thought it was f*kd, drove home, cracked a bottle of 15yr old whiskey and contemplated exactly the same as you.
About 4 glasses in my brain threw up an old thing I'd read on SAU about blowing boost pipes and the symptoms.
by the 5th glass i had found the pipe, fixed, n was good to go again (committed to skylines, not driving right away)
Was even thinking erh ill just sell the car really cheap and cut losses. Made me hate skylines for a short time haha WHAT WAS I THINKING! :b
Edited by jjman
Haha very funny. Hey one other thing while I'm here I had something similar. Took car to the drags and had a pop noise. Has been blowing a bit of smoke on and off for a while now. Had valve stem seals replaced at a large cost then still no better. Think it could be something similar? I have a catch can but there is a bit of oil in the Intercooler piping. Very odd.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
