hey guys,
Im selling my skyline due to the fact that i want to get my hands on a turbo. Its colour is Blue. Its done 117000kms. Its been serviced every 10000 kms since bought due to the requirements of the warranty that is transferable. The timing belt was replaced at 100,000 kms.
Its features include:
- Full electrics
- 5 speed auto
- Pod air filter
- Apexi SAFC
- Sterio system includes: JVC MP3 player with remote control, cadence 6 1/2 splits, pioneer 6 1/2 2 ways, cadence 12 inch sub and 5 channel audioline amp.
- Fusion Alarm and immobiliser
-$15000 ono
P.S, pics will be up soon
https://www.sau.com.au/forums/topic/42363-fs-1995-r33-skyline-gts/
my gf paid 18k for her 96 s2 r33 non turbo auto, tried to tell her it was too much but she liked the car, o well - on the plus it is one of the cleanest skylines i've seen...
GL with the sale, perfect nice first car!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
