Alright gents, here's a new one for me, from what I've seen on the forums at least. So, I have no spark in any cylinder for all intents and purpose. I pulled out the multimeter and started at the ECU, checking 12V Power from all my Spark Feeds (pins 101, 103, 105, 110, 112, 114) as well as 12V ECCS inputs (pins 49, 58, 59, 109). All were between 12V-13V EXCEPT for 103, Cyl. 2 Spark, which would come in at around 5V-6V occasionally. I went about checking my ECU spark earths (Pins 1, 2, 3, 11, 12, 13) as well as Main ECU grounds (pins 50, 60, 107, 108, 116) and all checked out as earthing for 12V-13V. So, with the exception of one faulty feed, I had 12V flowing from the ECU to the Ignitor Chip, in theory, but when checking the inbound side of the chip, I had no response on every pin that was supposed to be 12V. So...my question is What Gives? Are just my Spark feeds cut somewhere between the ECU and the Chip? Or am I looking at a faulty ECU?
Recap: I have good 12V and earths on all but 1 pin FROM the ECU, but at the plug to the ignitor chip, I have no power.
Attached is the pinout guide I've been using. It says the Grounds are pins 101, 103, 105, 110, 112, and 114, But I'm getting a Solid 12V from them, and a ground at 1, 2, 3, 11, 12, 13 and 10.
https://www.sau.com.au/forums/topic/423859-rb25-r32-unique-electrical-problem/
Which ECU are you using? Which RB25DET - S1 or S2? Because S2 has the ignitor built into the coil, and doesn't need the ignitor box.
Have you checked for continuity (0 ohms) along each of the wires between ECU and ignitor chip?
Series 1 RB25DET with Series 1 ECU and RB20 Harness, Ignitor Chip, Coil harness, and Coils.
00.3 Ohms resistance across all 6 feeds from the ECU to the Chip. But should those be 12V feeds? Because the multimeter shows them as grounds, not 12V feeds.
Alright, final check shows me that at the 3 pin grey plug that goes to the coil harness, as well as the 6 pin plug that goes into the Ignition chip, I don't have 12V anywhere, tested all 9 pins, no 12V feed from the ECU with key On, Off, or Cranking. Am I looking at a faulty ECU hopefully?
When measuring resistance, voltage is irrelevant.
Pins 101, 103, 105, 110, 112, 114 are for INJECTORS, not spark.
In general, the ECU does not supply power to anything, but provides a switch to earth.
By my reading of the circuit diagram, each coil gets power via a relay to pin 2. Pin 3 goes to earth. Pin 1 goes back to the ignitor module, where it eventually gets switched to earth through the ECU. Plus an earth from the coil side of the ignitor (7-wire side).
Yeah, I went through my post and a few more diagrams and realized that mistake. I'm aware resistance deals in Ohms and not Voltage, I first checked all 6 wires from ECU up to the Ignition chip for Resistance (Measuring 00.3 Ohms on all 6) and THEN checked for 12V coming out of any of the 6 wires to the Ignition Chip, and the 3 to the grey plug next to it.
So, you're saying that the earth readings at the ECU are correct, so where would my 12V feed to the ignition chip be coming from?
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
