Simple Q? Can u easily re-gap OEM Nissan Platinum Plugs,...as you can with copper?..Not talking Irridium now, Just Platinum (if there is a diff?)
Gone to 9psi. still at 1.2mm, my fault, I know now!!!(0.8mm!!)
Practical responses by members much appreciated!!
well once u take them out you hit the head down bit by bit till it is a 0.8mm gap. Thats how I was told to do it. And then you check on those little ruler thingy's that you slide the plug along to make sure your gap is correct. But I'd rather go and by new plugs that are gapped correctly just incase I stuff up something.
that's the thing CR33, the plugs are only 2 weeks old @ $26.50 each. Don't want to buy new ones ...ever again. (that's why I steered clear of Coppers, I just don't want to pull everything out again just to do plugs!!) I've heard that copper is slightly superior in output, but I won't notice.
So there is no physical diff b/w plugs? that's all I was after.....
you rock!
thanx bro!
Mark
The best way ive found to gap iridiums (same principle for platinums because you have to be careful) is to not use a hammer.
Use a bench vice.
You put the plug on the outside of the vice, with the spark plug earth strip (the bit you bend down to the electrode) and slowly tighten the vice untill the gap is acheived. This way its impossible to damage the tip, or break off the earth strip.
Use a bench vice.
thanx guys..........what an inovative lot we Skliner's are.
Thankyou.
Mark
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
