Hi, a mate is selling his 96 Skyline :yes:
Urgent Sale $7.5 ONO.
Please contact Cris 0448 163 394 for details:
  • 1996 JDM Series 2 R33 gtst import.
  • Front mount intercooler returnflow (black)
  • Aftermarket pod filter
  • Sitting on stock boost(7psi) never been boosted
  • 150xxx km chassis/engine rb25det
  • Timing belt replaced at 140xxxkm
  • Gktech dump to cat 3inch.
  • High flow cat. 5zigen catback 3" to 4.5" tip
  • WorkEmotion Limited edition gun metal grey. 5x114
  • 18 x 9.5 all round wrapped in Kuhmo KU31 235/45/18
  • Fronts on 80% rears on 70% tread
  • Pionner avicf30bt bought brand new. RRP: $2500
  • Oem window visors
  • Genuine OEM series 2 body kit
  • 400R front bar painted but not fitted
  • R33 GTR rear pods painted but not fitted
  • 17% window tint all round
  • Oem spoiler (not fitted)
  • Alpine Type G front splits 6.5"
  • Alpine type S rear speakers 6"
  • JL Audio and Jesen 4ch amps
  • JL Audio 12" sub
Edited by suztek
  • 4 weeks later...
  • 3 weeks later...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
