I'd love to plastidip my car, after I get my rims mid year, I'll be on my way saving for some!
Are you able to use a bottle spray gun and an air compressor, or is it better to buy an electric gun?
Any tips for matte white on white? My bonnets clearcoat is pealing, and I've got small blemishes/fading/scratches here and there, hence the reason why I'd like to give it a go :)
I painted the mini with a gravity fed spray gun and compressor at about 15-18psi. But I was told after I shouldn't have used it and for better results to use the electric ones.
Im no professional but I think the mini came out ok. It's only the second car I've painted.
I've had the matte black on my wheels for about 6 months, it's great stuff.
Only issues were: can't really clean the wheels by hand as brushes etc are too harsh, and tyre gel looks crap on plastidip!
Bear in mind that when you change tyres it will wreck the edges - I was lazy and just went over the wheels again, however it's started to peel again off one of the fronts, so I'm tossing up on just pulling it off all 4 and redoing it.
I've also pressure washed the crap out of the wheels every single week, it doesn't budge unless it's been 'picked at' on the edges. Even if you do a hatchet job of spraying it like me, you can blend it in easily and it tends to meld together as it dries.
To do wheels at least again, I'd just leave them on the car, put garbage bags on the rotors and do them on the car (after cleaning with dishwashing detergent). About 4 quick sweeps over each wheel is all they really need, ended up being 2 - 2.5 cans from memory.
How big are your wheels mate?
Hattori Hanzo 69, on 15 May 2013 - 12:13, said:
for those who have used it, would you plasti dip a roll cage?
I think that would be perfectly fine, but for the price you pay for plasti dip, why not just buy a few cans of matte black.
The only reason why you'd plasti dip is if you want to remove it later down the track.
  • 6 months later...
  • 3 weeks later...
-Cheap
-Easy
-Reversible
-Looks good when done right
-Can also add pearls etc
-Matte finish is the best/easiest for the DIY expert haha
-You can apply a gloss as well, I would recommend someone with a bit more know how and technique for this though
Plus make sure the car is alcohol prepped properly and for best results up to 7 coats
-You can purchase enough to do a whole car for anywhere between 3-5 hundred, so if you can DIY you're laughing!!
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
