hey fellas, I bought this chain and ABUS padlocks from a Sydney locksmith last november to secure my boat trailer to a electricity pole outside my house.
boat's now been sold and iv'e relocated to melbourne so PICKUP ONLY on this item due to weight (Box Hill South, Vic).
It's a 10ft / 3m hardened steel chain made specifically for securing motorcycles, trailers and such. Also 2 ABUS padlocks (one bigger to fit the chain and one smaller).
The chain uses 13mm hardened steel links and is fully jacketed. The ABUS padlocks each had a security cylinder installed with registered/secure key ie. the padlocks cannot be picked or bumped.
Neither the chain nor the padlocks can be cut with bolt cutters, you'd need an angle grinder and plenty of time to cut through the 13mm links (even longer on the padlocks). Only one registered key but 2nd can be provided by ordering from locksmith who has the code ($40 from memory).
I paid $350 for the chain (was on sale) and $100 for the bigger ABUS padlock and $80 for the slightly smaller. Then $100 for each padlock to have the security cylinders installed (can't be picked or bumped) so a bit over $700
Perfect for securing a motorcycle, trailer and maybe even a car. I used this to secure my boat trailer as it had to be parked on a busy street and almost got stolen on day 1.
Asking for $500 or best offer.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
