FMIC are an odd one. Most people cut the front bar to fit the pipes. This makes them a nono. If yours is properly fitted with no hacking etc it should be fine.
That's right Sin, if you have changed/modified your chassis to fit a fmic it is defectable but if it fits correctly it is allowed hence the time role have passed through Dickson with fmic. However it the car had a top mount intercooler like WRX's you cannot have a fmic without engineering because your average skyline, Silvia etc has a forward facing intercooler outside the chassis frame oem. Same goes for turbo lasers where they are next to the engine.
I agree and disagree. Cutting the reo bar i agree with being a big no no but when i did it on my old r33 i took the car to a panel beater and ask if there was any issues with cutting a hole in the part near the wheel well and above the chassis to put the pipe through and got confirmation that part of the vehicle if cut will not change the integrity of the strength of the vehicle.
Any one else done the same?
  • Replies 69
Dont rely on mechanics to get it right, read your adr's.
The adr's on your compliance plate are the ones you have to comply with.
Hole for pipe needs i think...
3mm reo plate, welded on 100-150 mm all sides from hole.
Something like that, cant remember details.
Not all rules make sense for specific purposes, some are there for general principals.
The hole in that spot on that car may not make the car any weaker, BUT, they want it done anyway cos they cant be that specific in the rules.
I've heard that since I did it. The car hasnt changed and still passes roadworthys.
I think they need to set the rules so that everything is the same.
Somethings are illegal on one vehicle and on another vehicle its legal.
Something to help people with the silly defects given to some modified cars on the side of the road. Namely Noise Tests on the side of the road.... Print this off and ensure that the officer at the time of the test follows the guidelines set out by the National Transport Commission of Australia. Note that this document specifically mentions the allowed equipment for noise tests angles and distances rpm for types of cars etc
http://www.ntc.gov.au/filemedia/Reports/NatStatExhaustNoiseTestSept2006.pdf
I will be adding up more soon but just advising that they are doing the same blitz through Westfield Woden at the moment and have confirmed with Westfield management that they are no allowed to be there unless invited by Westfield
Did management confirm they HAD invited them? Your post is a little vague there :P
How about a $40 car cover?
They cant see sht then, they cant see rego or number plate.
Just cover your defects and rego when parking.
And some kind of alarm so they cant f&@k with it.
Or tiny locks so it cant be moved without breaking something, and if they do that....... well, you can imagine.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
