Hi,
Have a few parts leftover from a rebuild/upgrade to my R33 GTS-T.
RB25 Factory Camshafts. These came out of my S2 Rb25, they look in really good nick.
Don't ask me lift or duration as I have no idea, whatever factory specs are, these are - $200
Stainless Steel High-Mount Manifold and Wastegate. This setup supported over 300kw with a 3076 on it.
No cracks, in reasonable condition. Only took off to go 6Boost - $250
I also have an X-Force dump pipe that used to bolt up to the 3076 if interested.
post-53650-0-59372800-1368071650_thumb.jpgpost-53650-0-51155400-1368071663_thumb.jpgpost-53650-0-61833000-1368071673_thumb.jpgpost-53650-0-11385300-1368071683_thumb.jpgpost-53650-0-69471500-1368071699_thumb.jpg
Factory Radiator. Looks shitty but worked fine. Upgraded to PWR with integrated coolers - $50
Tomei IN Cam Gear. Bought in error, don't actually need it. Brand new in box - $200
This suits RB20/RB25/RB26
All prices are free postage Aust Wide.
Thanks.
https://www.sau.com.au/forums/topic/424934-r33-gts-t-garage-clearance/
  • 3 weeks later...
PRICE DROP!!!
Don't ask me lift or duration as I have no idea, whatever factory specs are, these are - $100
post-53650-0-56396400-1368071569_thumb.j post-53650-0-85195800-1368071610_thumb.j
No cracks, in reasonable condition. Only took off to go 6Boost - $150
post-53650-0-59372800-1368071650_thumb.j post-53650-0-51155400-1368071663_thumb.j post-53650-0-61833000-1368071673_thumb.j post-53650-0-11385300-1368071683_thumb.j post-53650-0-69471500-1368071699_thumb.j
post-53650-0-10852700-1368071729_thumb.j
Tomei IN Cam Gear. Bought in error, don't actually need it. Brand new in box - $150
post-53650-0-21759900-1368071767_thumb.j post-53650-0-61724500-1368071777_thumb.j
Thanks.
  • 4 weeks later...
  • 2 months later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
