I recently replaced my turbo manifold studs as a few were broken.
since I have put it back together using 2 different factory manifolds, both are leaking quite bad.
I have been told the factory manifolds warp quite easily after all those years.
does any one know what I can do? get the manifold faced/machined ? if so how much does it cost and who would do it in Adelaide?
cheers.
https://www.sau.com.au/forums/topic/425082-rb25det-turbo-manifold-leak/
Its usually cylinders number 1 and 6 that leak as the ends want to bow out, but it could be somewhere else. Just look for the exhaust marks where it has been blowing out.
To fix it it needs to be faced or the high points taken off so its flat again. If you have a straight edge you can do it yourself with a file or honing stone it just takes abit of time to do. Otherwise any engine machine shop can do it. The ones I have had done it has cost me anywhere from $20-$50 depending on how bad it is and how long it takes them to get it straight again.
I am sure there would be plenty of machineshops in Adelaide who could do it.
  • Like 1
As above, I just did the exact same thing to mine, I went on a hills run, blew out part of my exhaust manifold gasket and snapped a few more studs. I looked at the manifold and it had high and low cylinder spots, I took it somewhere in Mt Barker and it cost me $50. Also used 5 layer SS individual gaskets and no leaking what so ever. As above, any machine shop and it cost me $50 to have mine done.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
