Item: RB25 1000cc injectors, JECS branded (if you dont know jecs they do all the afm and injectors for nissan) yes these fit standard rails and everything.
Cond: Brand new in packaging, never used. Come with the warranty papers and all the flow charts and stuff.
Reason for sale: Buying a house instead of cars atm.
Price: $600 firm
Item: Universal Fuel cell
Cond: used but in good condition, no dings or large scratches, could do with a wipe down once in the car, nothing major.
Reason for sale: buying house.
Price: $150 firm
Contact on 0407 056 817 instead of pm as i dont check them.
Edited by Jack_Sky
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
