Hey guys,
Just wondering where I can get a replacement globe/LED that goes inside the headlight level adjuster switch in my R34, as it doesn't light up anymore. I'm guessing it will be the same globe as my TCS switch (which still lights up).
Cheers!
oh hmmmm now that you mention it i dont think mine lights up either (i thought this was strange!!!) but as i got the car like that, i never knew any different. would like to find out!
so i'm sorry if im hijacking your thread but this might be useful for others too: what other buttons on the doors/panels light up?
I know my TCS lights up.
Foglight and headlight level adjuster should light up too.
As well as "Auto" on the driver's side window switches.
I've got a spare headlight level adjuster at home, I can open it up and take a photo to see where we can get em from :D
Not from Nissan lol, or you'd have to buy the whole switch to get a globe with it lol, so I've sent out a few enquiries about this little globe, hopefully I'll hear back soon :)
Will keep you updated :)
I have finally sourced some of these globes, in LED, and have changed my blown globe over.
I've got 3 left if anyone is interested, $4.50 pick up or $5.50 posted.
post-40415-0-77428300-1370253917_thumb.jpgpost-40415-0-27735400-1370253924_thumb.jpgpost-40415-0-50582000-1370253933_thumb.jpgpost-40415-0-31770600-1370253945_thumb.jpg
I've also just figured out how to get the numbers (0-3) light up too.
You need to use a sharp knife to ply out the plastic number plate, then flip it around, you'll notice behind the numbers, it is blacked out. So just grab a knife or something sharp to scrape off the black paint :)
post-40415-0-65769100-1370254990_thumb.jpgpost-40415-0-99428500-1370254999_thumb.jpgpost-40415-0-93295900-1370255007_thumb.jpg
Thanks Charles on the suggestion to scrape off the paint, that's much more useful than not seeing the numbers, don't know why they had it blacked out in the first place.! PMed you. Also, this will come in handy because I just realised my TCS doesn't light up anymore.
  • 6 months later...
Hey Charles,
Can you provide me with a part number or something of the replacement globe/led?
Interested in doing this to my R34 also, and perhaps the Auto switch for the electric windows.
Thanks!
Thanks man. I think I have some T3's in the cupboard.
Hey bit of a noob question, but how do you remove the adjuster? Ha...
Attacked it with a flat head yesterday, but kind of bitched out when it didnt budge
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
