I've been torn whether to do this for a while now, so I'm going to let fate decide.
On the market is my Nissan Stagea, I'm sure would of heard about this car by reading the build thread on this forum. Or seeing it in action at Eastern Creek.
I bought this car back in March 2011 as a complete stocker. Since then I have spent countless amounts of cash, and time on it.
Spec sheet:
Nissan Stagea WGNC34 Spec Sheet
Model - 1996 Gray Nissan Stagea RS4 Series 1 DAYZ version
95xxxkms
12 months Rego!
Power:
315hp/235kw on 18psi (last dyno run with restrictive intercooler, probably around 260kw now at 20psi)
Engine:
Standard RB25DET
Gates Racing timing belt
Gates Racing water pump
Turbo setup:
Kando TD06H-20G 10cm Turbocharger
Aeroflow turbo lines
Turbosmart 40mm Compgate
Standard exhaust manifold, modded for external gate
Screamer - plumb back hybrid pipe
3 inch metal intake pipe
3a Racing black air filter
ECU:
Haltech E11V2 Standalone computer
Haltech 3 bar map sensor
Fuel:
Highflowed OEM injectors
Walbro 255LPH lift pump
1 litre surge tank
Bosch 044 fuel pump
Ignition:
NGK BCPR7ES Spark plugs
Cooling:
Run It Hard! oil cooler kit
Aeroflow oil cooler fittings
Power steering cooler
HKS Type S intercooler kit
ASI 42mm radiator
GKTECH top radiator hose with sensor fitting
ASI lower radiator hose
Nismo 62 degree thermostat
Oil control:
1L catch can with Run It Hard! Baffles
Run It Hard! triple baffle RB25 cam covers
Exhaust:
Run It Hard! 3 inch dump pipe w/ flex joint
Hooker Aero Chamber Muffler
Run It Hard! Blast pipes
Run It Hard! 3 inch exhaust (for track)
NISMO rear muffler (for street)
Dahtone Racing de-cat pipe
Transmission/drivetrain:
Removed front shaft
Nismo clutch pivot
Nismo gearbox mount
HEL braided clutch line
R32 GTR gearbox PUSH TYPE 79xxxkm
R33 clutch pedal
R33 clutch master cylinder
R33 clutch slave
modified brake pedal
GKtech Solid shifter bush
NPC 10inch 5 puk sprung centre carbotic button clutch
Nismo 5kg billet flywheel
Diff:
S13 R200 non ABS housing
Viscous LSD
4.08 final
5 bolt half shafts
5 bolt drive shafts with thicker boots
Suspension/Chassis:
RS4 front strut brace
solid subframe risers
S14 rear subframe
Tein Superflex Wagon coilovers
Swift racing 12kg springs front *Z70-178-120*
Swift racing 10kg springs rear *Z70-229-010*
Cusco front upper camber arm
Adjustable tension/castor rod
GKTech V2 camber arms
GKTech V2 toe arms
OEM boxed traction arms
Cusco OS type rear strut brace
Whiteline 22mm front sway bar
whiteline 24mm rear sway bar
GK tech solid diff bushes
Modified link arm, bearing carrier raised 40mm
Braking:
R33 GTS-T Calipers**
RDA slotted rotors front
RDA slotted rotors rear
Bendix ultimate pads front
Bendix ulitmate pads rear
HEL braided brake lines
R33 GTS-T Handbrake setup**
GKTech brake master cylinder stopper
Exterior:
DAYZ front bumper
DAYZ side skirts
DAYZ rear spoiler
DAYZ rear lip
Nissan Altima Clear front indicators
Clear side indicators
Kouki tail lights
Rolled & Pumped guards
Debadged rear hatch
LO-11-VO number plates
NA grille
M35 Stagea rear wiper
Interior:
Daikei boss kit
Sparco style 350mm leather steering wheel
GK tech black drift button
GK tech black handbrake cover
R32 GTR driver seat
R32 GTR passenger seat
Series 2 Manual console
Series 2 manual shifter surrond
Audio:
Pioneer DEH-3350UB Head unit
Pioneer TS-A1674S 6 inch speakers
Instrumentation:
Greddy profec B spec II boost controller
Race tech 52mm oil pressure gauge
Race tech 52mm oil temp gauge
Race tech 52mm water temp gauge
Race tech 52mm boost gauge
Run It Hard! flat gauge slot panel
NOTES:
Pictures aren't up to date, I will get some new pictures of what the Stagea looks like this weekend, it's pretty much how it is now in those drifting photos.
The body has a few scratches and dings, most from the previous owners but some within my ownership too.
Paint is in good condition, no fade, no missing clear coat etc.
Interior is good, GTR seats are a little worn, but standard front seats are shmick
cluster plays funny buggers, the original one died last year and will be included in the sale so new owner can get it fixed if they wish.
the rear guards aren't the greatest but do the job. As you can see in the pictures above.
The wheels on the car are currently Euro line mismatch, this is how the car will be sold.
It's also permanent RWD and ABS has been disconnected.
Obviously this car has been built to my needs, and has been built with the intention of drifting.
If you're after the following:
Somewhat practical (depending on what height you set it at)
under the radar (cops don't bat an eyelid ... unless your on gate)
different (S and R chassis are so overrated)
Then you better get in touch with me!
Jokes aside, if someone takes it off my hands cool. If not then I will keep it and find another way to kill my debts.
Tell em the price son!
I'm chasing $16,000. I am slightly negotiable, very slightly.
If you've read this whole listing and happy with what you see, feel free to send me a PM.
Please, no time wasters and no I will not be parting out.
Will come with some standard parts, shocks/springs, seats etc.
There's probably more info that I've missed, so yes PM me if you are interested.
Adam.
Some quick iPhone pics of the Stageas current state. Needs a wash and all that jazz but you get the idea.
Edited by Run-It-Hard
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
