Hey all,
I own a r33 GTS-T tuned at 13.5 psi. When im a bit heavy on the right foot and start to hit a red line
my boost controller just starts beeping until the revs drop down. Ive grazed through the manual and tried to figure
it out solo. But im a bit puzzled, any help is greatly appreciated, thanks in advance!
Edited by Jbowie2703
Cold weather made mine spike, it was tuned in the summer. I just learned to control my right foot lol
And yeah set the peak warning higher if the beeping annoys you
Edited by macaroni646
