LOCATION = SYDNEY MOTORSPORT PARK WET PAN
TIME TABLE
7:00AM GATES OPEN
7:30AM SCRUTINEERING
8:00AM DRIVER SIGN ON
8:45AM DRIVER BRIEFING
9:00AM START TRACK ACTIVITY
4:30PM END TRACK ACTIVITY
Please read below for event guide, terms and conditions and standing regulations.
1) SPECTATORS
Everybody is welcome to spectate at our events. Entry fee is only $5 per car, which is donated to a Cancer Foundation.
2) SCRUTINEERING
All cars will need to pass scrutineering and get signed off by our Chief Scrutineer before being allowed on track.
Main Safety requirements:
- Brakes
- Brake lights
- Seat belts / harnesses
- Windscreen wipers
- Headlights and tail lights for night events.
- Seats installed correctly
- No Leaks
- Oil Catch can for unregistered Vehicles
- All wheels nuts tightened
- Fire Extinguisher (Recommended not compulsory)
- Secondary bonnet restraint is compulsory. If you do not have one, please bring a short (1 mtr) rope and our Scrutineer will assist you with installing it.
- Safety comes first, any cars not meeting requirements will not be allowed on Track.
3) DRIVER/TRAINEE:
Non-flammable clothing (Nylon not accepted).
Clothes must cover you from neck to wrists to ankles.
Enclosed shoes with socks must be worn.
Helmets need to have the at least one of the following sticker of approval.
FIA 8860-2010, FIA 8860-2004, AS1698, SFI 24.1 and Snell SA2000
3.1) PASSENGERS/TRAINEES:
Trainees must be minimum 16 years old to ride in any car of your choice, at drivers discretion.
Parental consent required for Passengers/Trainees under 18.
$30 members
$50 non members
4) COST:
Driftmob Members
$130 Per Person (Must have a valid existing CAMS license).
Non-Members
$150 Per Person (Must have a valid existing CAMS license).
4.1) CAMS Licensing and related costs
-CAMS license can be issued on the day of event.
- To hold a yearly CAMS L2NS (Level 2 Non-Speed) or L2S (Level 2 Speed), you need to be a member of a CAMS affiliated car club.
- A temporary slip will be issued on the day for yearly purchases and original copy posted out within 6 weeks.
- You can choose to pick up your original copy at our next event as well.
4.2) Driftmob Membership
-Driftmob Memberships can be taken out on the day of the event.
Package 1 $175 Full yearly membership (includes long sleeve shirt, membership card, stickers and yearly L2NS)
Package 2 $125 Full yearly membership (includes long sleeve shirt, membership card and stickers).
Package 3 $85 Full membership yearly renewal only.
5) PAYMENT OPTIONS
5.1) PREPAY
Account Name: DRIFTMOB INC
Account Number:259 589
Bsb:03 2372)
Financial Institution: WESTPAC
Please mail your confirmation receipts to "[email protected]" or "[email protected]"
- Include the number of entries and the names of the drivers you have paid for.
This will reduce a lot of confusion and ease our administrative process.
5.2) Credit Card
- Payment can be made over the phone with the Club Secretary.
Contact: Angela
Phone: 0406 669 635 (5pm-9pm) Monday - Friday.
5.3) Cash or EFTPOS on the day.
- Entries are subject to availability. There are no guarantees of availability for entrants on the day.
- No reserving spots on the subject of on the day payment.
6) MISCELLANEOUS
- Entries Capped at 40 Cars.
- Trainees/Passengers permitted in cars at the discretion of the Clerk of Course. Subject to skill level of driver taking passenger.
- Our track days are run based on providing surplus track time for our members, therefore during day events we won't stop for lunch but keep running through the till finish.
7) CONTACT:
For more information on the Driftmob Car Club visit: http://www.driftmob.com.au/
Or our Facebook Page: http://www.facebook.com/DRIFTMOB.CAR.CLUB
Urgent Enquiries please Email:
1) [email protected]
2) [email protected]
3) [email protected]
Regards,
The Driftmob Crew.
https://www.sau.com.au/forums/topic/425394-driftmob-drift-day-wet-pan-smsp/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
