Hi guys,
back in the market for these, not too fused about new or used just after LH/RH set, don't need them straight away but quicker would be better as i am going overseas in 6weeks.
im located in Sydney, please feel free to text me offers as i don't regularly check the site.
Mobile: 0404 146 127
Cheers Nino
