Genuine z32 AFM including a Plug in excellent condition, %100 Genuine,mesh is attached on both sides
z32 afm's are good for supporting up to 350rwkw+ great upgrade for s13,s14,s15, r32,r33,r34,GTR's
I have 2 of these Jecs z32 afm's and both come with Tomei plugs and are in mint condition with the mesh attached on both sides.
Price: $230 Each for 1 x z32 afm including the Tomei plug . Price is firm and not negotiable
Local Pick up from Glenroy - Melbourne (North Western suburbs) or can post Australia wide for an extra $15 each
Message me on here if interested and ill get back to you ASAP
Edited by G4orce
https://www.sau.com.au/forums/topic/425611-genuine-z32-afm-tomei-plug/
Genuine jecs z32 afm & tomei plug sell for about $350. These are in very good condition.Price is firm.
I know you said price is firm but its too close to a new price how about $200
Edited by G4orce
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
