Hey guys,
For sale is my R31 Skyline. I've owned it for 3 years and bought the car stock, so any parts which have been changed or removed can be put back to standard or given to the new owner if wanted. I have changed the engine oil, power steering fluid, coolant and brake fluid every 2000km and the diff oil/gearbox oil 8000km ago. The coilovers, clutch, brakes, rebuilt tailshaft and diff are all less than 8000km old.
Brief rundown of the parts/work done to the car
This is the main work done to the car:
-Rebuilt diff 3.89 gears, bearings, axle seals, wheel bearings, mini spool
-K&B Clutch Engineering custom made clutch
-Extractors and 2.5" exhaust, all Hurricane mufflers/high flow cat, made on car
-Rebuilt tail shaft, new uni's, bolts
-S13 Silvia front LCA/Hub/Knuckle, S13 tie rod ends, longer tie rods, HSD HR coilovers, SR20DET brakes
-S13 coilover rear, custom made top hat adapters, adjustable panhard rod
-All suspension and steering bushes replaced with nolathane polyurethane
-Power steering cooler, oil cooler and filter relocation
-Hydraulic handbrake with VS commodore calipers and new QFM A1RM pads
I'm happy to take $2000 with R31 suspension/brakes or $3500 with the S13 coilovers and brakes etc. If it doesn't sell by the time the rego runs out (Roughly 5 weeks) then I'll wreck the car down for parts. Would be a shame to wreck such a good car, it's really well set up for anyone wanting to do track work or drifting, or just a weekender or daily too.
Thanks.
295000_10150826386547176_1798917551_n.jp
  • Like 1
https://www.sau.com.au/forums/topic/425791-r31-sedan-manual-rego/
  • 3 weeks later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
