Soda blasting is much more gentle on panels than conventional "sand"blasting. I've even heard of a form of media blasting that uses crushed walnut shells.
They reckon they can strip individual layers of paint, and even leave body filler intact. They also claim that they can strip areas without having to completely disassemble a car.
The advantage with soda blasting, is that the residue can be washed out as it dissolves.
http://advancedsodablasting.com/?gclid=CNWBlpibyrcCFUdfpgod7F8AAw
https://www.sau.com.au/forums/topic/426400-sandblasting/#findComment-6878010
Awesome.
My original thought would be to remove everything. Just leaving the shell and blast the whole shell and all panels and stuff and re-priming and painting and getting all holes, dints everything back to 100% normal.
How much do you think the avg price would be for a mechanic to strip a whole car down to bar bones just the shell?
https://www.sau.com.au/forums/topic/426400-sandblasting/#findComment-6878049
Awesome.
lol...probably more than your car is worth...
https://www.sau.com.au/forums/topic/426400-sandblasting/#findComment-6878201
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
