^point proven exactly
Stupid pumpkin doesn't even know that other manufacturers made cars with the GTS appellation. Some of them were very large V8s. Like my Monaro. My 1971 Monaro. That I owned in the 80s.
Little boy should shut up, shouldn't he?
Um hate to break the bad news to ya matey but this is a Skyrine forum, not a holden forum... *facepalms. stop replying with crap and leave this forum to people who know whats going on, let this forum get back on track please no smartesness
no disrespect here, but GTSboy knows what he's on about !! If you don't know what your talking about you need to pull your head in and not look like a goose
:yes:
lol he knows what he's talking about? I've read both of your posts on a few threads and can tell both of u aren't smartest tools in the shed, again please don't confuse OP any more then he is. Just let the experienced guide him, cheers.
Gts4door is on the ball with the possible r&r theory as I took it for a drive today when she's on around 6 psi. Or what my boost guage believes is 6 psi. The car went really good good consistant power thru the rev range. No lag no flat spots/surging
Went like it should have. But I haven't touched the boost tee yet. It will only hit 9psi or so when I plant my foot to the floor. This run I just have it about 3/4 throttle
And as for lifter. Ill probably rule that out as it didn't sound like lifter. And only does it on boost if your off boost driving the car. Noth
And as for lifter. Ill probably rule that out as it didn't sound like lifter. And only does it on boost if your off boost driving the car it doesn't make one noise
It's a very quiet motor
Also guess while I'm on this topic I have my 32 a run tonight and now I've upped the boost it seems to make some weird whine up around 13 pound. I drive it on 10 daily. Only usually does it past 10 pound. It's like a really high pitch noise. It's intermittant at first I thought it was air getting in my windows. But this time they were down
Not sure if srs? GTSboy would have to be one of the most "switched on" guys on this forum...
Dude I had a similar noise in my R32, with stock turbo. Ran 12-14psi and it sounded like a cop siren when coming onto boost. I opted to swap to the RB25 turbo and noise disappeared (good bang for buck mod).
I just bought a s1 33 also and getting the ticking noise
It sounds like a manifold gasket to me
Or even to thick of oil. As soon as it gets to temp its gone so does not seem to be that bad
for the other issue your gearbox is not in snow setting is it
my kids where playing in the car and pressed it on snow without me knowing and man i thought the car was f**ked
Revving and going nowhere etc.
And i would check the plugs to i fouled mine in the first day i got it
Gapped some new copper ones to 0.8 and away i go
Edited by Tommmay
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
