  • Replies 44
R34 GT-V MODEL
2.5lt NEO 6 Engine & loom & ecu -1200
Limited slip differential(factory option) - 350
Rear window wiper assembly - 50
Driver airbag - 150
Dash pad incl Front passenger airbag - 200
ABS PUMP - 70
Power window reg - 80 each
Rear spoiler - 100
Bootlid with spoiler holes - 100
Turbo brakes (factory option) - 250
5 stud conversion - 400
Two tone front & back seats (black/grey) - 200
Climate control unit - 150
Cluster -100
Coilovers (nismo springs) - 300
Coupe front doors - 200 each
Front windshield -100
Rear windshield - 100
Alloy radiator - 100
Abs sensors (all) - 100
Steering wheel - 120
5 speed manual conversion - 1000
Interior carpet - 100
Centre console - 80
Roof lining - 50
Rear taillights - 100 each
Rear bumper including reverse lights g
** Running gear sold **
Still have all interior bits
rear lights
spoiler
nismo coilovers
back bumper
gtt brakes
abs sensors front/rears
alloy radiator
both coupe doors
climate unit
dashpad
glovebox
cluster
gearbox loom
Pedal box
******open to offers guys ******
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
