Trying to figure out why the car is idling so rough, the fuel pressure guage seems to fluctuate, at idle its between 42-43, holding the throttle open on 2000rpm it will hold on 42psi, release the throttle and the guage rises for a second on 46psi and the engine tries to stall, but the recovers and the pressure is back at 42-43psi.
just need to know if that sounds normal....
and if the voltage at the pump is fluctuating or getting too high could that affect idle quality or does the computer compensate for different voltage.
Another thing, does changing the setup to a twin scroll 6boost and turbo affect the engine breathing enough to create a rough idle?
Edited by AngryRB
https://www.sau.com.au/forums/topic/427393-voltage-affect-idle/
may have made some progress here, in the power fc theres a function for "injector Correction" that was set at 1.000
raising this to 1.500 and also raising the idle to 1000rpm , the engine sounds almost normal and wont try to stall, can anyone make sense of this?
yes its smoothed the idle out and it now doesn't stall on me anymore, seems to idle at 1200rpm when I declutch quickly instead of wanting to stall too..
the fuel pressure has some down a little and holds firm and only increasing with a flick of the throttle, so funny how much its changed
will have it tuned properly in a few weeks, its interesting how a change to a 6boost manifold and a GT30 instead of a GTX30 has required more fuel, ( assuming its not a vacuum leak) .
Its a Power Fc with a Z32,
Do you think having a 4inch intake pipe and a Z32 would cause some false readings due to volume and speed of gas flow thru the two different sized pipes.
Edited by AngryRB
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
