help with decreasing knocking
I've got a R33 94 GTSt with a Power FC and when using the Power FC the knock levels are to high, i have yet to get it tuned so the Power FC is still factory set.
My commander shows at peak hold:
Ign timng 42 deg
air flow 4830 mv
knock 69
any help on getting the knock down would be good as it's a bit hard to get it tuned at the moment cos I live so far away from the nearest tuner and I'm waiting on getting a new turbo befor I get it tuned.
mods:
Power FC, HKS FMIC, HKS Pod, AVCR and 3" kakimoto exhaust with 3" front pipe.
running 98 octane fuel.
https://www.sau.com.au/forums/topic/42854-engine-knock/
My knock was a lot higher than 69.. What I did was to pull timing from the whole map untill it stops... this will give you a good idea how much you will need to pull from the inj map later... Once you have worked out how much timing you need to pull set the base timing back to where it was, get a friend to drive the car and in map trace mode pause it when it is pinging...
Go to the appropriate map point in the ign map and pull some timing out at that point... It will take a while on the road so dont rush it... You can add fuel at the same map points to attempt to decrease knock..
I suggest you get a wide band o2 sensor and a A/F meter from say Jaycar.. (not the best tuning tool) but better than nothing... ( I will get flamed now)
I take no responsabilaty if you stuff your engine... This is just what I did to mine to keep it safe until I get a dyno tune at a reputable Tuner...
You can also try running octane boost as tha APEXi PFC is set up for 100 oct fuel until you get it tuned.. Its expensive but cheaper than a rebuild....
Other wise keep of the throttle.. We all know how hard that can be
https://www.sau.com.au/forums/topic/42854-engine-knock/#findComment-874728
Ign timng 42 deg
air flow 4830 mv
knock 69
mods:
So you are running a power fc which has been installed out of the box without ever being tuned?
If this is the case either have it tuned immediately or replace it with a factory ecu until you can afford to do so. The tune that comes on the power fc is a base tune only. Driving your car around on this tune is very dangerous.
https://www.sau.com.au/forums/topic/42854-engine-knock/#findComment-874752
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
