Located in SE Melbourne however can ship at buyers expense
Complete GTR for wrecking minus the following:
- Wheels
- Complete Motor & Gearbox
- Exhaust
- Brakes
- Front Seats
- Radiator/FMIC/Piping/BOVS
- Front bar
- Dash Surround
Here's a start:
- Diff - $500
- Rear Driveshafts - $200 pair
- Rear Hubs - $200 pair
- Rear Subframe - $200
- Tailshaft - $200
- ATESSA 4WD PUMP - $200
- Space Saver - $100
- Bonnet - $600
- Left & Right front guards - $450 pair
- Boot Lid with Wing - $400
- Rear Bar Skin - $200
- Rear Reo - $150
- Tail lights - $200 pair
- Rear Garnish - $150
- Boot trim - $200
- Side skirts - $400 pair
- Rear window - $250
- Rear 1/4 Glass - $150 each
- Door - $250 each
- Door Trims - $150 each
- Mirrors - $150 each
- Electric Window Motors - $150 each
- Glass front doors - $150 each
- Driver Electric Window Switch - $100
- Passenger Electric Window Switch - $50
- Centre Console Gauge's (3) - $200
- Complete Set of Locks + 2 x GTR KEYS - $250
- Floor mats (5) - $150
- Rear Seats - $350
- Dash - $250
- Centre Console - $200
- Rear 1/4 Trims - $150 each
- Carpet - $200
- Seat Belts - $50 each
- A Pillar Trims - $50 each
- Roof Lining - $150
- Standard Front Swaybar - $50
- Standard Rear Swaybar - $100
- Standard upper arms - $150 pair
- Standard uprights - $150 pair
- Standard lower control arms - $150 pair
- Standard castor rods - $50 pair
- Front Crossmember - $250
- Front Guard Lining - $250 pair
- Brake Air Ducts - $250 pair
- Air Con Condensor - $150
- Air Con Compressor - $150
- Air Con Drier - $50
- Air Con Lines - $150
- Standard Intercooler - $350
- ABS Unit - $350
- Standard Washer Bottle - $50
- Overflow Bottle - $50
- Front Strut Brace - $150
- Rear Strut Brace - $150
- Passanger Side Guard Raiser - $150
- Standard Side Indicators - $50 pair
Thanks
Darren
https://www.sau.com.au/forums/topic/428569-wrecking-1995-r33-gtr-silver/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
