RBMunkie Posted July 14, 2013 Share Posted July 14, 2013 (edited) Spent last hour making a thread with pics.Site wouldn't post it.So f^$% doing it again.ALL PARTS COME OFF A GTR THAT WAS RUNNING FINE BAR A BUSTED HEAD GASKET.Nearly died, need money to pay off medical expenses (seriously.)PM ME WITH WHAT YOU WANT, AND I WILL GIVE YOU A PIC.ALL PARTS FOR SALE.I WILL PROVIDE PICS WHEN YOU PM ME BECAUSE I AM NOT SPENDING THE NEXT HOUR PUTTING PICS ONLY TO HAVE THE PAGE MAKE ME LOGIN TO HOME AGAIN AND DELETE EVERYTHING.Not posting anything as I work five days a week, so you'll have to come to north sydney to come get them. Sorry.MMMMMKAY?Keeping brakes, seats, key and ign' barrel.BODY PARTS:Hood (with liner) - $280Front guards - $100Front bar (minor scratch on front left corner) - $200Boot lid + Wing + badges - $180 (Wing paint has the clear baked off, other wise in good nic.)Grille - NO BROKEN TABS/CLIPS! - $100Front lower guard bodykit pieces - $25 each.Guard liners - $50 a corner.Door shells (drivers side has a scratch down low, no dents though) - $150 each IF YOU WANT COMPLETE DOORS WITH GLASS TRIMS ETC, 300 each, bolt 'em straight on your car.Wing mirrors - Pass side has baked clear - $50D, $35PDoor rubbers - $200 for the lot.Door kick panels - $10 each with push clips.Hood latch, support, front brace and cable - $150Headlights - $100 each (including bulbs, no broken tabs)Indicators, LH has broken top tab, $25 bux for it, $40 for RH indicator (with bulbs)ENGINE/MECHANICAL:C.A.S: $200C.A.S Alloy bracket - $30Cam gears aftermarket "Spool" - $40 each.Cams - $80Coil packs on rails - $220 for them plus the rails.Coil pack loom - $50GTR Injectors on rail - $150Injector loom - $60Radiator (flushed and clean) - $60Aircon crap all of it, pump, etc - $100 for the lot (engine bay stuff, not inside stuff.)Fuse and relay box - $100.Airbox with filter - $100.Washer bottle with motors (And fluid!) - $80Coolant bottle - $40Alternator - $80P.S pump - $120Brake booster - $150P.S reservoir - $100Cam covers - $50 eachCoilpack cover (No badge, wrinkle paint) - $80Front cam cover - $60Intercooler - $150 Intercooler piping - $120 for the lot, front cross pipe, main pipes all the way from turbo to intake.Intake plastics (lower air box thingo, rubber pipes, and plastic piping) - $10 a piece.The big thing on the pass side of engine bay with all the brake lines running to it, HICAS, etc. thingamijiggo - $200 sounds fair?Turbo manifolds - $80.Turbo manifold heatshields - $30 each Stock turbo's - $100 each.Turbo piping - top hard pipe, no badge $35, top rubber pipe $25, metal pipes off turbo's - $15 each.Exhaust - $300 from the turbo's back.Intake plenum (when I finally get the F@#$ing thing off) - $200ITB's - $200 (unless I magically get an L28 Motor and a Zed then they are going too.. lol)Head with valves (no cams) again when I finally get it off... - $450, valve seats in good nick, will provide the Tomei restrictor with it if you want.Sump - $250.GASKET KIT, complete factory one - $250.Fuel pump & Tank - $260Clutch cyl, booster and lines - $100Block - $1200.Pistons - $150 for the lot.Rods - $150 for them too.Crank - $240Fly wheel - $250All the oil lines and oil block, returns etc - $3004x Airflow meters - $80 a pop.DRIVELINE:Gearbox - $450.Clutch (good, good feel to it) - $200Tail shaft - $180Rear Diff - $350Front diff - $280Rear cradle with control arms, etc - $200CV's, front and rear - $40 each.Front hubs with bearings, no discs or calipers - $120 each.Rear hubs same dealio - $100 each.Front suspension arms - $200 for the whole shebang each side.Factory suspension, good nic - $250 the lot.HICAS steering rack - $120Front steering rack with rack ends and tie rod ends - $180.Sway bars - $80 each (F&R)INTERIOR:Rear seat - $180Floor mats, F&R - $140 for the lot.All interior plastic trims (bar center fascia as it's busted), so pillars, rear pillars, rear side seat trims, B pillar trims, kick panels etc - $500Carpet - $200Gauge cluster - $120 genuine 147 k's.Center triple cluster - $50AC controls - $50Rear aus compliance window brake light - $100.De-ioniser - $140Rear parcel shelf - $150 (will throw in speakers, I think they work.. lol)Roof lining - $140 (needs a clean, otherwise has no burns or tears I can see.)Top center interior light fixture (complete unit) - $60.Rearview mirror - $40 (good condition)Sun visors - $25 each, pass has mirror.Dash - good condition as far as I can tell, NO VENTS - $300.Interior fuse box - $100.Interior AC box - COMPLETE - $250. (looking for the heater valve control motor thingo for a guy who has PM'd me, hope it isn't inside the box. lol)Glove box with string stopper - $60Factory ECU - $150Seat rails - $Not sure as I may be keeping them for the RX7 as I am keeping the seats, as the RX7 seats aren't comfy for me as I now have to use it as a daily driver.Seat belts, GENUINE NISSAN good nic - $160 for the lot.All boot trim - $200.Space saver tyre original - $130.EXTRAS:Shell, registerable - $3000, no rust (includes glass)4x 225/40/18 Pirelli's - $200 at 50%ish treadANYTHING ELSE JUST ASK. :-) Edited July 14, 2013 by RBMunkie Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/ Share on other sites More sharing options...
Memphisxxx1 Posted July 14, 2013 Share Posted July 14, 2013 side skirts? rear pods? Will you split the interior plastics im after the passenger side rear quarter window pillar think is the b piller Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927099 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 Do the side skirts come off? lolThe rear quarter surround plastic?$30 for it.This is the car buddy. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927126 Share on other sites More sharing options...
gtr0321994 Posted July 14, 2013 Share Posted July 14, 2013 Still have the rims Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927138 Share on other sites More sharing options...
Memphisxxx1 Posted July 14, 2013 Share Posted July 14, 2013 yeah same skirts as mine any who is have pm'ed about pillar! Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927166 Share on other sites More sharing options...
Bl4cK32 Posted July 14, 2013 Share Posted July 14, 2013 too bad your not closer to SA. I would have bought the lot. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927184 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 It is sitting on jack stands in the garage as I sold the rims about a month ago.lol. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927213 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 Pics of random stuff.Aircon gas tank.AC pump.All the AC gear.ClusterBelts.Rear mats.Center light.Alternator.Brake light.PS pump.Center grille.C.A.S. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927220 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) PASSENGER DOOR locking mechanism has been sold to gtr0321994.Shifter boot and heater control valve sold to: (as far as I am concerned.. lol)luke GTR Edited July 14, 2013 by RBMunkie Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927245 Share on other sites More sharing options...
Gts-t Posted July 14, 2013 Share Posted July 14, 2013 Shame u wont post, would like front guards Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927287 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) Rear quarter window plastics sold, and splash tray sold to NISMOFront bar and Reo + lip sold toRyno Edited July 14, 2013 by RBMunkie Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927318 Share on other sites More sharing options...
DeaN20 Posted July 14, 2013 Share Posted July 14, 2013 hey mate could you post a picture of the dash, and also would sell the dash surround seperately, if so how much? Thx Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927336 Share on other sites More sharing options...
R32FREAKK Posted July 14, 2013 Share Posted July 14, 2013 where you located mate? and how much for the whole front end? ie guards, bonnet, grille, bonnet latch etc. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927348 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 Dash:No bubbles I can see.The controls around the gauge cluster?$40.R32FREAK - the front bar and reo is sold.But I still have the guards, hood and latch and front support and brackets. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927363 Share on other sites More sharing options...
DeaN20 Posted July 14, 2013 Share Posted July 14, 2013 Oh sweet, thanks for pic; ill have a think abt it. But also do you have the pipe that connects the twin turbo pipe to the intercooler piping (in pic below) and would you sell it separately as i need one badly. Thx. Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927417 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 Yeah man, I have it.This one: Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927423 Share on other sites More sharing options...
RBMunkie Posted July 14, 2013 Author Share Posted July 14, 2013 Ac controls, Front splash guards, center gauges and seatbelts sold tor32-25tPassenger window switch sold toSiR_RB Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6927512 Share on other sites More sharing options...
AVGR Posted July 14, 2013 Share Posted July 14, 2013 Chasing the following in good condition >> 1. Interior door handles >> 2. Rubber seals/linings around door windows >> 3. inside triangular pieces opposite the side mirrors cheers adam 1 Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6928174 Share on other sites More sharing options...
krayzie32 Posted July 15, 2013 Share Posted July 15, 2013 Pm sent Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6928646 Share on other sites More sharing options...
R32FREAKK Posted July 15, 2013 Share Posted July 15, 2013 pm'd replied about guards bonnet etc Link to comment https://www.sau.com.au/forums/topic/428622-r32-gtr-wrecking-black-urgent/#findComment-6928699 Share on other sites More sharing options...
