Hi guys downshift is on again tomorrow over at Eagle Farm, if anyone is interested will be meeting with a few others at Albion McDonalds between 1:00pm & 1:30pm and leaving to head to venue not long after 1:30pm.
This is not an SAUQLD club event nor will it be covered under any club insurance, if you have SAU stickers on your car try and behave for the sake of the club.
Below information taken from Downshifts facebook event.
If you want to avoid the bumpy road/any chance of gravel. I'd suggest coming in this way: http://goo.gl/maps/5ds3T
As you can see from the above picture, there is residential down this way in Hamilton. PLEASE BE QUIET AND MINDFUL! And please exit past Option 1, NOT past the apartments. We had a couple of complaints last time.
The CONDITIONS OF ATTENDANCE are the same as always:
YOU are responsible for the guys you bring to the meet, and hang with. If they act like idiots, we will find out who it was. Brisbane is a very small place.
THROW RUBBISH IN THE BIN BAGS. Use them, we put them up for you guys. If they're full, just chuck it in your car and throw it out next time you fill up.
*****ABSOLUTELY UNDER NO CIRCUMSTANCES SKID TO LEAVE.***** PLEASE LEAVE QUIETLY SO THAT WE WILL BE WELCOME BACK
Date: SATURDAY JULY 20 2013, 2pm - dark
Location: 297 Macarthur Avenue, Hamilton. (Down the end near Northshore riverside park)
Cost: $5 per person
The meets are open to any cars, whether they be JDM, Euro, Hot Rod or Aussie. The idea is to have like-minded, respectful, appreciative people there, who can also follow some very basic rules. IF you can do those things, we'll see you at the meet, and you'll be welcomed with open arms.
https://www.sau.com.au/forums/topic/428914-downshift-20072013/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
