hi
after fitting new exhaust today(3'' turbo back xforce) car started fine and idled for 15 min
we took it off hoist and was reversing it out when it stalled
after some diagnostics we discovered there was no power to fuel pump
all fuses ok
all relays ok
its got me stumped
i hot wired fuel pump,car started and was not throwing check engine ect,so i drove home
drive home was fine,no stalling ect
its now sitting in driveway
i cant seem to locate a wiring diagram anywhere on web
has the ecu cut power for a reason??
or cuold it simply be a wiring issue
can anyone shed some light ?
have i missed something obvious
or is there a known problem with wiring to fuel pump or sensors when fitting bigger exhaust
i could run a fused and relayed wire to power up on ignition to run pump,but i would rather find the fault
thanks in advance
ian
Edited by traceysr33
https://www.sau.com.au/forums/topic/429293-helpno-power-to-fuel-pump/
another question on sensors
the 1st sensor behind turbo is an oxygen sensor??
the second one in rear of cat is an egt sensor??
even if these were not reading correctly due to new exhaust it wouldnt shut down fuel pump,or would it??
well ive checked the ecu(in pass kick panel?) and term 18 (fuel pump power supply) has no power
i have pulled rear seat out and got to fpcm
if its faulty would that stop the ecu powering up the fuel pump?
thanks
found issue
9th fuse from bottom on rh side of fuseblock in cab kept blowing
upped it to 15 amp and power was restored to pump
dont know what fuse is cause its all in jap,but its obviously in the fuel pump circuit
had the fkin back seat out
removed and replacer fpcm
and all it was was a fuse
never trust anyone else to say "yep checked all the fuses under dash and there all ok"
even if he is a mechanic
time for beers
heaps of beers
thanks guys for all your assistance
found issue
time for beers
heaps of beers
take a photo of the jap name of the fuse. peeps on here could translate it
thats done already, have a search and you can print and paste that one over the top of your cover if u wish
thanks mate
that may explain why it cut power to fuel pump
dont spose you want to translate the rest for everyones benefit?
thanks again
