Does Anyone Know The History Of This Car? (Link Inside, R32Gtr)
I understand this is also for sale on these forums and the owner regularly posts too.
Hopefully someone can give me some history on the car though, I understand it's been selling since June @ $23,000. Now for $15,000.
Help would be greatly appreciated. You can PM me too.
http://www.carsales.com.au/private/details/Nissan-Skyline-1990/SSE-AD-2239660/?Cr=15
Thanks a million.
$3280..... "PAID CASH"
Yep, he's from Lalor alright...
I'd be a bit wary of that big a price drop... But then again probably just realised that there's no way that someone is going to pay $23,000 for a stockish R32
Hahah I noticed that too.
Well when I did some digggin' I found that the car isn't stock really at all.
Look at this advertisment from June:
http://www.ebay.com.au/itm/Nissan-Skyline-GTR-32-Twin-Turbo-5sp-Manual-RB26-/161044162558?_uhb=1&pt=AU_Cars&hash=item257efae7fe&nma=true&si=CRy%252BUltF96%252FbNlUNkLIOo5HabTI%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
300KWATW.
I wouldn't trust anyone that puts a transformers sticker on their GT-R....
there is nothing wrong with what he has done, parts are often worth more off the car, or maybe he wanted to keep bits and pieces for his future R34......go and have a look and judge it in person, might be ok
at least his second ad isn't full of lies such as 'never been boosted' etc, if you go and have a look dont let on that you know about the old ad, ask him some questions and see if he is honest...that will tell you alot.
Edited by Gza36
  • Like 1
