Due to work commitments, I am about to start parting out my DR30 project, with alot of parts available, is there much interest from anyone in WA for anything?
I really can't be bothered shipping anything large interstate. Most parts are brand new.
Parts include;
Iron mask front end
Vented FRP Iron mask bonnet
Jenesis FRP front lip and side skirts
Jenesis FRP front bumper (needs repairing)
8 point bolt in cage from Japan.
Complete interior (minus seats) with several brand new parts from Nissan. Uncracked dash.
Recaro seats with mesh head rests and R30 rails.
Jenesis 260 km/h speedo with 10,000 rpm tacho
Front and rear windscreens
Brand new coupe rear lower chrome window trims.
Jenesis oil cap and gear knob
If anyone in WA is interested, the shell (unregistered) is available as well, can do a deal if anyone wants the shell and all the parts. Shell is currently in 2 pac primer.
At this point in time the engine and gearbox is not available.
Cheers,
Steve
Edited by masTers
https://www.sau.com.au/forums/topic/429919-any-r30-coupe-owners-in-wa/
Willing to ship, bulky items you will have to organize shipping yourself (to the point of having someone pick it up from my place as I am too busy with work to drop it anywhere)
Edited by masTers
Will send the front bar if you are patient with me in getting it shipped.
I am happy to wrap it in bubble wrap or cardboard, if you can organize to have it picked up from me (Dianella 6059 for reference)
IF it needs to be dropped to a depot, It could take some doing, but not impossible. I am in the middle of busy season at work so for large items I am quite time poor.
I am willing to post the rear moulds (assuming this is what you mean?)
The following parts are gone;
Iron mask front end
Jenesis FRP lip and skirts
Grey tail lights
Shell is gone but the Body Loom and engine harness are still available (no ECU)
Edited by masTers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
