Hey guys,
I've finally decided to give my silver r34 gtt a full detail but I'm in need of advice,
I've figured that the usual routine Is;
Wash
Clay bar
Polish
Sealant
Wax
Is that right?
My paint is pretty average so should I need to wet and dry sand it?
How do I go about polishing? What polishes do I know what to use?
Any help would be much appreciated
https://www.sau.com.au/forums/topic/430676-first-full-detail-advice-needed/
DO NOT dry sand. If you wet sand (i'd avoid doing this) start with 2000 grit then work your way up. You need to know what you're doing as you need to avoid going through the clear, then you need to get the sanding marks out.
Heres the process id recommend:
Wash with dish soap, helps to strip existing wax and majority of grime. dry.
Spray with 15% IPA dilution (mix with distilled water) - spray over car, use one microfiber followed by another for drying (so hold one in each hand). Will strip any remaining wax left over in the hills and valleys of the paint.
Clay bar & soft ph balanced wash soap for lube. dry
Compound...if you want to actually properly remove scratches etc, then you will need to compound....
IPA spritz again.
Polish.
Wash with soft ph neautral soap. dry.
Seal (let cure for 24 hrs after wiping off).
Apply wax.
Plenty of compounds and polishes out there on the market, up to you.
Ok mate thanks alot :) would you recommend any polishes or compound?
No worries.
Also I should mention that when you clay, make sure you clay in straight lines.
You don't need to use much pressure either, clay works with friction....
For my car I used Menzerna FG500 for compounding, and Menzerna PF2500 (polishes out the compounding marks) and SF4000 (jewelling polish). I got realllyyyy good results with those using a DA polisher machine.
Another good combo I've heard really good things about is meguires M105 (compound) followed by M205 (polish), but I'm not sure if you can get it locally.
Benji can i pay you to come and do my car, and remove panel gaps?
But no seriously I wish i had a garage, I would actually attempt to detail my car but alas no garage, not gonna bother.
Lol, yes sure. Once I finish uni this semester we can organise something if you like. Would be more than happy to detail your car.
No guarantee about the panel gaps though =P.
Do you usually do it a panel at a Time with all two compound and polish? Or the whole car with each compound then the second then the polish after?
Compound whole car first, then polish whole car, then step 2 polish whole car.
You will get a bit of dusting from compounding usually, so easier just doing everything in stages.
You can try Meguiars Ultimate Compound then Meguiars Swirl Remover both can be found at any auto shop and are very easy to use if you haven't done something like this in the past. Surprisingly good results with dual action polishers, on par with more expensive Menzerna products I've used in the past
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
