Breaking - as in: "my Skyline will be breaking the world land speed record."
Braking - as in: "I was braking into turn two when I locked up the rears"
imagine how those porkas feel when the r31 came 7th outright in the frist event before braking the front control arm
ref. http://www.skylinesaustralia.com/forums/sh...79&postcount=96
Following Pete's suggestions and breaking SUPPER late in the 4th event the short course at wakefield... turns out the bastard set me up... I'll get mine one day!
ref. http://www.skylinesaustralia.com/forums/sh...05&postcount=73
:D
It's even in the same thread - nice one boiz ! :) :) :)
PS - SUPPER - Super. :) :)
https://www.sau.com.au/forums/topic/43100-spelling-lesson-for-fatz-majanal/
  • Replies 43
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
