G'day all,
Just fitted a new steering wheel to my 33 and was driving to work today and the HICAS light came on :eek:
I have heard from some people that this sort of thing can happen when an aftermarket wheel is fitted.
Can someone tell me what I can do to fix this or if it is anything to worry about at all???
Cheers,
Zacos
:lol: :lol: :lol: :P
https://www.sau.com.au/forums/topic/4311-hicas-light/
Nismogirl,
The Boss kit I bought is HICAS compatible :P
'the light doesn't come on straight away....only after about 10Km.
Does anyone have any other suggestions as to what has gone wrong or If I just stuffed it (was very careful about putting it together)
any suggestions appreciated.
Zacos out
:burnout: :burnout: :burnout:
https://www.sau.com.au/forums/topic/4311-hicas-light/#findComment-68935
We still have this problem. Do you notice that its when you are driving along a freeway... or somewhere where you aren't turning much? This is our problem and whenever we get on the freeway our hicas light comes on because the sensor in the steering wheel isn't making contact.
Or.. our first problem with our hicas came when the wire going from the back of the speedo to the computer wasn't connected. Also cutting out the abs, speed sensor and hicas.
https://www.sau.com.au/forums/topic/4311-hicas-light/#findComment-71167
The HICAS light only comes on when I am driving to work (along the freeway!!!!)
My only worry is that the alignment of the rear wheels may be affected when the light comes on, thereby trashing my rear tyres
:cool::P :P
Guess I will have to pull it apart and have a look!!
thanks for your help :P :P :P
later :burnout: :burnout:
https://www.sau.com.au/forums/topic/4311-hicas-light/#findComment-72597
What the???:eek: :eek:
I wouldn't have thought that the HICAS and the turbo timer where related in any way.
Does the HICAS light turn off before the car does???
Because with my timer, if any thing is switched on/off (headlights, indicators, car put into gear) the car shuts down.
who knows.....I don't know enough about the workings of the turbo timer to be able to give any sort of informed answer. :) :)
anyone else got any ideas???
Later
:burnout: :D
https://www.sau.com.au/forums/topic/4311-hicas-light/#findComment-73009
  • 3 weeks later...
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
