1) TOYO R888 SEMI SLICKS - located Campbelltown
Fronts are approx 99% tread left, rears approx 85%. Only used on street, on a weekend driver. Never seen track/circuit.
Will sell in pairs or a set. Front Pair $550 ono. Rear Pair $450 ono. Or buy together for $900 ono
Only negotiable to serious buyers. Low ballers will be ignored. Will need $100 deposit to secure tyres, and then I will have them removed off rims if only buying tyres.
http://i301.photobucket.com/albums/nn68/Kaneb86/IMG_1222.jpg[/img
2) KOYA RG TEK 18" Rims - located Campbelltown
Front are 18x8.5 +18
Rear are 18x9.5 +18
No buckles or dents, only a couple minor scratches. RRP $1299. Selling for $800 ono
Can sell tyres and rims together for $1600 ono
Apologies if im missing it - but what are the rims specs please - offset, width front and rear etc.
Gav
0403 21 6969
All in the ad, but will PM you anyways.
Feel free to PM me. Be advised that I'm not interested in posting these interstate, as I don't have the time to package these up.
  • 3 weeks later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
