Mugabetown - Whoretownin' At It's Worst.
It all about the limiter... Tried to give out to many scissors on happy laps
Never lined me up :(
In saying that I didn't stand a chance but some inclusion in the destruction of your motor would of been nice :P
Sorry. I tried to line you up a few times. But you kept Corning to quick.. I'm sure there was a few here that assisted in the pop
After a discussion over a couple of glasses of scotch, Scott is staying on as VP.
Did he give voice to his concerns as to why he was looking to stand down?
I am glad he is staying on.
Take some time to get clarity and then let us know what the plan is going forward.
He was concerned that he may not have the time commitments - which is true if he was acting alone. Acting as a team, this issue is alleviated - to an extent.
