Mugabetown - Whoretownin' At It's Worst.
i like it when you forget you ordered something and then it shows up and you have no idea what it could be.
its like a surprise present to yourself, except that its something you actually wanted.
It's like surprise sex
When you deliver it -
Not receive it. That's not fun.
I never forget :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
