Mugabetown - Whoretownin' At It's Worst.
I want this http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=5_148&products_id=553
but it is worth in the same ball park as the new car, life is annoying
Well, when you include shipping, customs and GST, it is very close to a new car!
why? your car was already built not too long ago???
Why would you spend $25K on going through all that again for more cubes?????
Dont be silly Bunta, use the funds you have to buy the car you mentioned before and with any other disposable income you may have fix the GTR i.e. crank trigger, tuning etc....
Because OS Giken 30! Cant find the long motors anymore which sucks, they were good, ready to drop in including adapter plate
Ok guys, have had a think and chat to a few different people regarding Clint's perma ban.
The general consensus is that a ban was warranted, but not a perma ban.
I've raised this with Duncan, who is the Admin who started that thread and Revhead, our admin.
Now comes the time where I can push it further and push for answers, or let it go and remain placid.
My question to you guys is, if you were in my shoes, how would you deal with it?
Don't just give me yes or no, thoughtful responses would be more useful.
Thanks,
Tony
Few thoughts.
Dealing with it in the open here is unlikely to please the people in charge or do anything other than fire up the locals and start some sort of whorpocalypse
Unless we know what was said we cant really frame our responses, Did it sound like Duncan and Revhead are inclined to do anything about it?
Does Clint even WANT to come back? He didnt sound too keen the other day
Few thoughts.
Reason I did it out in the open is because history has shown this stuff will get derailed very quickly.
Neither Duncan nor Revhead have responded.
I really don't know about Clint.
Since the above two factors are in the air, that's why I thought to ask others. Move it to Members maybe?
I would say that's the most appropriate place to deal with it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
